brake warning light, why ?
Discussion in 'The Garage' started by R72K5, Dec 6, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    needing opinions,
    the brake warning light is all the time in the truck except for everyonce in a while it will go out when pedal returns after applying brakes but as soon as you hit pedal again the light returns and stays on as usual.
    truck is 83 K20 and it sat for years untouched never ran once until recently and the brakes work fine no problems at all,
    i plan on bleeding out all old fluid out of system with new fluid when i can
    what do you think ?
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    It could be the sensor on the proportioning valve.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The light comes on because you have lost half of your brakes hydrolic system. My guess would be bad wheel cylinders. Having set that long it is already too late to just flush out all the fluid. The damage/rust is already done. If it was my truck I would just replave the entire system. It doesn't cost that much on a chevy.
    MC $12
    Wheel Cyl $4 each
    front calipers $13 each.
    For about $50 ($100 with tax here in CA) you can have a whole new system!
  4. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Does the '83 have the black box next to the resivor? If so, with the ignition off, disconnect the top plug on the box, turn on the ignition for 30 sec without starting the engine, shut it off, reconnect the plug, and give it a try. If you have a coumpter problem, this will clear it.
  5. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    those are junkyard prices in michigan. /forums/images/graemlins/grin.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  6. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    They are j/y prices out here too! The damn j/y wants as much as the part is worth rebuilt! I rebuilt some wheel cylinders once because I didn't have that much cash at the time. Later I found out that the rebuild kit cost more than a rebuilt wheel cylinder! Talk about learning a lesson on how cheep chevy parts are.
  7. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    I would go with your plan of bleeding the brakes. Make sure to check your entire brake system for leaks though.
  8. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    You may just be low on fluid, if your pads are getting worn the fluid level will drop as the pistons and w/c move out to take up the slop, this will cuase a drop in fluid level.
    I would still check all lines, calipers and w/cs for leaks though.
  9. dyeager535
    26,976
    Doesn't sound like it, but have you made sure that the emergency brake switch isn't the culprit? No, it doesn't sound related because brake apply gets the light to come on, but it's easy to check.
    FWIW, I'd say that at least 50% of the time when a brake system is bled, that has been abused or sat for a long time, the master cylinder will fail. Sludge/corrosion builds up in the master cylinder bore, especially further in (which is where the piston goes when you bleed brakes, notice how far the pedal travels compared to normal) and apparently, when the old seals (probably somewhat hardened) get pushed into the sludge/corrosion, they get cut, which means the MC is no good anymore. End up with a spongy pedal that eventually fails at an inoppurtune time.
