brake warning light
Discussion in 'The Garage' started by mxrcr589, Jun 28, 2003.
  1. mxrcr589
    mxrcr589 1/2 ton status
    Apr 17, 2003
    148
    poop
    on my 1990 gmc jimmy my brake warning light stays on, atfer i release the parking brake it gets a little dimmer but it still stays on so i know its not my parking brake. i just got my brakes serviced like 1 month ago, anyone have any ideas of what it is???
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    The switch under the dash that touches the tab on the brake pedal, you can adjust that, give that a try.
    Also see if the wire got disconnected from the prop valve, there is one connection at the valve, and one right around the frame horn, just trace the wire back a bit and you will find it.
