Brake Wobble
Discussion in 'The Garage' started by stockk5, Apr 29, 2006.
  1. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    Hey everyone, i just put some 37" humvee tires on my k5, im running dana 44 front and dana 60 rear, when i am braking and down to 35 my truck starts shaking violently back and forth then under 25 it stops. Any idea what could cause this? warped rotors? sumthing odd w/ the tires but why only at 35? thanks Mike
  2. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    warped rotors?
  3. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    well if it didnt do it before the tire wheel swap then..
    hmm
    otherwise check rotors and for any looose steering joints or loose steering box or loose anything else
    good luck
  4. virgilh
    virgilh 1/2 ton status
    Sep 8, 2004
    343
    Sacramento California
    loose bolts
    i second that i had 33s on my first blazer when i went to 35s it went in to convoultions when i was braking i put the 33s back on it stopped. i found the left side u bolts wernt loose but they wernt tight enough so i went over the front suspension with a fine tooth comb and the problem went away, found left side u bolts and a worn tie rod end i guess the leverage difference was enough to cause a wobble
