brakeline part numbers for rear disc.....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by thatK30guy, Sep 1, 2005.
  1. thatK30guy
    Jan 12, 2001
    32,076
    55
    I need to run to the parts store to get some rubber lines for calipers for a rear disc conversion.
    I don't want to use the actual part number to fit the certain rig with D44 calipers. I want shorter length hoses that fit the 7/16" banjo bolt.
    Anyone know a part number or what specific vehicle to tell the parts guy? Remember, I need shorter lines than the stock K-series hoses. :thinking:
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    pm grundy99. IIRC, he used front lines off a chevette or something like that. Try any early ('77 or so??) GM car like the Monte Carlo/Camaro or something like that. IIRC, most of the early GM cars used the 7/16 banjo bolt in the front calipers.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    TTT....anyone else? :confused:
  4. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    I've always heard 79 chevette front hoses.
  5. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    The short hoses I used for the swap I did (years ago) were Raybestos BH38421 or Auto Zone Brakeware 77024.
    I am not sure of the banjo bolt size in these lines though.
    I used Eldorado calipers at first, then switched to 10bolt 3/4ton calipers.
  6. K5Kell
    K5Kell Guest
    Did you find/install the lines? Looking to do same thing, just looking for info.
    -Kell-
  7. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I bought some for the front of a '79 Chevette, they are the same part number for both sides, and are about a foot long.
  8. gn4u2c
    gn4u2c 1/2 ton status
    Oct 29, 2003
    287
    Pa 17329 zip
    I used a set of 85 ss monte carlo hoses they fit the same and have the protective sleeve by the banjo for us hardcore 4x4 guys.
  9. K5Kell
    K5Kell Guest
    What hard lines are those? What did you use for the rest of your swap; bracket, caliper....
    -Kell-
