Brakeline Removal?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by little79k5, Sep 11, 2002.
  1. little79k5
    little79k5 1/2 ton status
    Mar 27, 2002
    230
    panama city, fl
    Any special tools required for a 83 1/2 ton? Any tricks?
    keith /forums/images/icons/confused.gif
  2. dyeager535
    26,982
    191
    Use a tubing wrench. (do not delude yourself here...you may get lucky a few times, but when you finally round off the head of one of these with a normal wrench, you'll kick yourself)
    Also, when trying to loosen rusted or stuck fittings, make sure the wrench fits tightly, and give the wrench a sharp wrap with a hammer or something. Don't follow through, you just want the sudden shock, as it typically breaks the corrosion bond at the fitting, which is why its stuck in the first place.
  3. little79k5
    Mar 27, 2002
    230
    panama city, fl
    is it called a brake tubing wrench or just tubing wrench? can i get it at a auto parts store ya think?
  4. little79k5
    Mar 27, 2002
    230
    panama city, fl
    and what happens if i already rounded one off!?! whoops
    vise grips?
  5. dremu
    Feb 27, 2000
    15,970
    462
    East of San Francisco
    Also called flare wrenches, they're the ones with the four-sided heads (or is it five?) Anyway, they go on at the hose part, then you slide them up and tweak away.
    Dorian is 100% on the money. I almost killed my rear brake line last week; do it right, use the right tools, and be patient.
    And use lots of WD40 or other tight-mofo-nut loosener as personal preference ;-)
  6. dyeager535
    26,982
    191
    I know them only as tubing wrenches. They come in different sizes just like box/open ends, except tubing wrenches fit on 6 point bolts only, and look like a box end wrench, with only one "flat" cut out, so it uses 5 of the 6 points on the nut, instead of 2 like an open end.
    If its rounded off, you can try visegrips, but since the fitting is essentially hollow, unlike a regular bolt, what typically happens is they crush, and then there is nothing to grab on to.
  7. little79k5
    Mar 27, 2002
    230
    panama city, fl
    one more thing. i want to pick one up on the way home from work. isn't it a 3/4" ??
  8. dremu
    Feb 27, 2000
    15,970
    462
    They're usually one size on each end. I thought they were smaller than that -- 5/8" or 9/16" -- but I drove the Isuzu today, so I couldn't tell ya.
    Get a set of 3/8 thru 3/4", comes as three wrenches I think.
