Brakes, for 52" Swap
Discussion in 'The Garage' started by petryshyn, Oct 17, 2005.
  1. petryshyn
    petryshyn 1/2 ton status
    Jun 6, 2004
    150
    Yorkton,Sk
    Just wondering what would the best way to get brakes up to the front for a 52" swap. I was thinking about a center drop but how would that work???
  2. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    No need to change the brakes just make sure you have flex line from the frame to the caliper that can handle the drop. I have superlift lines on mine and they were long enough. I also relocated my lines to right below the frame rail for reasons other then the 52" but it added some length there.
    I have seen a few guys come off the PV valve and T the front two lines together and then use a center drop off the engine crossmember with a rear T out to the ends the flex from there. Two much work for me and with the soon added hydro I have too many lines as is.
  3. petryshyn
    Jun 6, 2004
    150
    Yorkton,Sk
    How long are your lines? And were did you get those lines?
    Thanks.
  4. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
  5. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Got mine on ebay IIRC 15"
