Brakes: From 1/2 ton to 1 ton?
Discussion in 'The Garage' started by ChevyCaGal, May 21, 2003.
  1. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Ok, I'm not finding the answers I want with a search... maybe I am not look up the right key words... anyhow, I am going to be going from stock 10 bolt axles, front and rear, to a Dana 60 front, 14 bolt full floater rear. What do I need to do for my braking system? The rear 14 bolt has disc brakes. What can I use I have now, if anything, what will I need to replace? My front lines suck, they are barely long enough. I want to get rid of them anyhow. Also, my parking/emergency brake, it's warn. It doesn't work like it should. It's not tight at all. What brands are good to buy, what brands should I avoid in buying items. What would be an ideal set up? Keep in mind I will be using this for a lot of street driving and this is a heavy sucker. I'm not much into wanting to lighten her up at this point and will be adding weight to it someday with things like a cage and bumpers. I want to do it once, and do it right with quality parts. Since I am going to be saving up for crossover steering, adding a few bucks more for a good braking system won't make much difference to me. Thanks! /forums/images/graemlins/cool.gif
  2. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    You should be able to use the brake lines and the caliper bolts.I suspect the calipers and rotors are different. The D44 and the 10 bolt are different so I assume the D60 will be as well. I purchased 10 bolt fornt calipers for $15.95 each from Pep Boys. I would get 4 new calipers for that price. Get some pads for $20 a set while you are at it.
    Chances are the c clip holding the ebrake cable in has worked its way off on one of the rear drums.
    You should also do some research on the proportioning valve. A factory 4 wheel disc brake car will have a different one than a rear drum front disc setup. Most people do not care about this but I think it is worth looking into if you want it done the right way.
    Good luck
  3. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Anyone else got any info? /forums/images/graemlins/confused.gif /forums/images/graemlins/smile.gif
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> IIRC there was a HUGE thread on this about 5 or 6 months ago. </font>
