brakes keep going out. ive been getting lucky, but itll run out sometime.
Discussion in 'The Garage' started by Silver84k5, Aug 5, 2003.
  1. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Sometimes when at low RPMs my brakes will go out, usually right when i start my truck up, but sometimes after its been running too. It doesnt happen all the time either. I never know when its gonna happen, Hasnt happend at speed yet....
    I bled them yesterday and i think i did a good job.. maybe not...
    I heard that the proportioning valve either WORKS or DOESNT. so i dont think thats the problem cuz most of the time the brakes work....
    Is it air in the lines. or the master cylinder. I dont see any fluid coming out from the rear drums. so i dont think its a Wheel cylinder....
    can somone throw me a bone? Thx.
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    Re: brakes keep going out. ive been getting lucky, but it run out sometime.
    [/ QUOTE ] sounds like they are not getting enough vacuum
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I agree with MudHog. Sounds like the vacuum booster is bad. Check for vaccuum leaks or a bad booster.
    John
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Sounds like a good time to convert to Hydraboost /forums/images/graemlins/thumb.gif
  5. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Thx for replies.
    No hydroboost. only heard bad things abuot that combination with Hydro assist...
    I know the Brake booster is behind the mast cylinder, is that the same as the vaccum booster?
  6. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Sounds alot like the master cylinder is giving up, Working intermintently. Cheap and easy to swap.
    John
  7. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    when the booster goes out and isnt getting vaccum, the pedal will feel like you dont have power brakes and you wont..
    to check the master...if you apply the brakes lightly, does it do it, or does it do it when you apply them hard?
  8. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Re: brakes keep going out. ive been getting lucky, but itll run out sometim
    it does it without notice... Never has happend at speed, and it doesnt matter if i hit hard or soft....
    When i do hit the brakes though it sounds like Air.... i cant explain the sound in words but its like Air getting compressed? damnit i wish i had a audio of it. kinda sounds like Chssssssssssssssssssssssssssss..... does that makes sense? hahaha doubt it.
  9. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    If your hearing air rushing then its most likely have to do with a blown out vacuum booster.
  10. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    master cylinder.
  11. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    IT does that sound all the time, everytime i press the brakes.... vaccum booster is the brake booster right? the big ass bubble behind the master cylinder?
    Jeremy thx... im gonna replace that when i replace the brake booster ;P
  12. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    Re: brakes keep going out. ive been getting lucky, but it\'l run out sometim
    [/ QUOTE ] yes you are correct r4replace that and then bleed them again and you should be good to go /forums/images/graemlins/thumb.gif
  13. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    My cylinder went out on the 79 I had, 30 miles form on a trail I never been on. didn't help that the leaders already left and it was foggy. I made it all the way home using the e brake and even drove to work the next day..changed it after work and drove home. It's wasn't fun and that was only 35's. I'd love to put hydro boost on the wagon. My burb has it and it stops way better then my dads burb. (90 3/4T TBI350-th400)
