brakes on 14 bolt
Discussion in 'The Garage' started by Janitorjim8, Sep 7, 2005.
  1. Janitorjim8
    Janitorjim8 1/2 ton status
    Feb 21, 2005
    215
    Illinois
    So i have the oppurtunity to get a 14 bolt and a dana 44 both with 4.11s in them already. I am just wondering what ways there are to upgrade these brakes, I really want to do 4 wheel disks. Any help like what years were compatible or any companys that sell anything would be great. If I keep the Corporate 10 bolts I'd also like to upgrade those too.
  2. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    14 bolts are cool!!! You can throw on calipers and rotors from the front of a 70's Chevy truck, all you need to do is build or buy caliper brackets, some brake lines and MAYBE a proportioning valve. :eek1:
  3. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
  4. Janitorjim8
    Feb 21, 2005
    215
    Illinois
    another question, on this if its 8 lug, will there be a way for me to change it back to 6 lug?
  5. NerdBoy
    NerdBoy 1/2 ton status
    Dec 24, 2002
    429
    Southern Illinois
    Not cheaply. I went up that road about a month ago. Apart from the random used adapters for sale, it can be difficult to justify all that is needed for the conversion. The hubs on a 14 bolt won't fit through the center hole in a 6-bolt rim.
    If you can machine your own hubs and come across a deal on adapters, it's a viable route. If you are really bent on keeping the 6-bolt rims, you can drop about $500 on a new set of hubs, which might be the easiest and strongest way to do it. Bear in mind that if you have 15" rims, and they are alloys, they may not fit over the drums.
    I found it cheaper to just get a set of 8-bolt steel rims. I got to keep the 15" tires I already had, and didn't have to mess with adapters.
