Brakes Overheating
Discussion in 'The Garage' started by stevesa, Mar 22, 2004.
  1. stevesa
    stevesa Newbie
    Mar 22, 2004
    I have a 1996 Toyota (yes Toyota) T100 that has the front end from a 1971 Chevy Blazer. It is running 15 inch wheels with 37 inch tires. The front breaks are stock Chevy and the rears are stock Toyota. I need a solution that will allow me to keep the stock sized front rotors, but gain much better cooling. The brakes work well in cooler weather, but now that the warm weather is here the fronts overheat and the calipers lock.
    TIA!
    Steve
  2. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    I don't know from nuthin but is everything all nice and clean or is it all gummed up? I would think that the Chevy stuff would be more than beefy to handle the weight of your truck. The other thing could be are you ridin your brakes all of the time like in rush hour traffic? That would make them all hot and what not. Also, are they releasing ? If not you might check the master cylinder as well. Good luck to ya in the future.
    Allan
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Why are they getting too hot? Are your calipers sticking, or do you have an airflow issue?
  4. stevesa
    stevesa Newbie
    Mar 22, 2004
    Not ridin' the brakes. It's a stick shift! They just overheat from time to time. When they do overheat, one of the front calipers sticks. Once it cools down, it releases. Every thing is nice and clean.
    Just flushed the brake system and replaced the DOT 3 fluid with DOT 4. Hope that helps some.
    Thanks for the replies! Any additional thoughts are greatly appreciated!!
  5. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    Sounds like you need to replace your calipers.
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I bet the problem is that your rear brakes arn't doing anything at all!
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Bingo, I concur /forums/images/graemlins/thumb.gif Try bleeding them again and make sure the rears are adjusted out until they slightly drag. Don't forget some sliding grease on points where shoes touch backing plates (but not on lining). /forums/images/graemlins/k5.gif
  8. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    Try replacing the rubber brake lines up front. I the inner liner on one of them has ruptured, it will cause the caliper to lock. /forums/images/graemlins/thumb.gif
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yep.
    Any time calipers are replaced, brake hoses should also. Just like any other hose, they rot from the inside out.
