Brakes Problem¡¡ Help Please!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jaguargt, Mar 14, 2003.
  1. Jaguargt
    Jaguargt Registered Member
    Mar 14, 2003
    46
    Guatemala
    Hi guys, i have a 83 K5, 6.2, great truck, the problem is every time i hit the brakes, the truck pulls me to the driver side really bad, really bad, what should i check? thankx in advance.
  2. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    Pass side caliper. It's probably not working. AFter that, there's a ew other things to check, but I'll leave that to the experts.
  3. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    the rotor could be scored or the pads are gone on the side its pulling to. or bleed the caliper ont he side its not pu;;ing to
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Could be several issues including but not limited to:
    Stuck caliper (stays applied)
    Frozen caliper (won't apply)
    Worn out rubber line (bulging)
    Bad rotor
    Bad pads
    Frozen caliper bolt/slide C10/D44
    Stuck Caliper D60 (where it "slides" along the backing plate)
    Oil/debris soaked pads.
    Pinched hard line
    Crap in Prop valve (not that likely, but.....)
  5. Jaguargt
    Mar 14, 2003
    46
    Guatemala
    Thanx, to everybody, i'll check all those things.
