Brakes Problem any ideas?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Confederate9, Apr 18, 2002.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    hey guys, i have a 85, stock 10 bolts front and rear.
    My problem is when i drive i hear a "CHIRPING" noise, i cant figure out what it is, but when i tap the brakes it goes away.
    even when i tap the brakes and keep my foot on the gas it goes away. also when i make a right turn it goes away and or when i make a swirving movement to the right.
    so i dont know what it could be othe rthan i think that its in the brakes.
    i replaced my drum brakes about 1 month ago, but the noise started about 3 weeks ago.
    any ideas on what it is and how to fix it?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Could be front brake pads.
  3. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    i would guess front pads...could just be brake dust...
  4. shoeless
    shoeless Registered Member
    Nov 1, 2001
    99
    N/A
    Mine was doing the same thing. I just did a brake job, pads, calipers, and rotors. When I went to take off the spindle nuts, I could remove three out of four by hand. They were so loose the bearings were making noise, and I could shake the hub. My bearings looked good, so I cleaned 'em up and repacked 'em. The things runs so quiet now. I would look into that with yours.
