Brakes squeeking for no reason
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Me89'Jimmy, Apr 8, 2003.
  1. Me89'Jimmy
    Me89'Jimmy 1/2 ton status
    Oct 6, 2002
    127
    Sykesville, MD
    My brakes on my 89 started to squeek a few days a ago, i figured either water or time for a new set of disc and drum pads. I threw my truck up on the lift and took a peek, i had more than 3/4 pad left on all 4!! I cleaned out all the gunk and brake pad shavings. The damn things still squeek!!!! Any suggestions /forums/images/graemlins/eek.gif
  2. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    First is it really your brakes? U-joints are known to squeak (sometimes while under the stress of braking)....worth a shot. I have also had the metal "squeal" tab on the front pad bend to a point of touching the caliper prematurely and causing a squeal.
    Don't know if any of these are your problem, but worth a shot.
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I'd recommend checking out the tabs as well. I've seen this happen a lot.....
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Another thing is take the pads out and look at the face of them. If you got them real hot then they might be glazed and will look real shiny.
  5. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I'd pull the pads, de-glaze them with some sandpaper or a die grinder (PLEASE wear a ventilation mask to do this) and CHECK THE RUNOUT on the rotors and drums...Do the brakes squeak when you are braking or when you are just motoring along?also, throw some anti-squeal stuff on the back of the pads...IT WORKS...
    Chris
  6. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    Out of curiousity, if your pads are glazed can damage to the rotors occur? Also is there less braking power with glazed pads?
    jason
  7. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Hit the pads and shoes with some sandpaper and then wipe them off (both sides) with brake cleaner. Put some RTV on the back side of each pad and put it back together. Sometimes the squeaking is actually nothing more than the pad vibrating against the piston or caliper body. It's even more common on those brakes that people don't bend the tangs over to keep them from moving around.
