brakes squeeling BAD!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ftn96, Jan 15, 2002.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Ok, like over night the damn things, sounds like front driverside. When Im slowing at regular decel upon a stop light or turn at red-light or what ever, it is ear piercing... But when Im on them HARD, nadda? Whats a simple fix? I have the "goop" on the back of the pads. And I've always sprayed the shinola out of everything when I do and work on or around the brakes. So I know there is no grease involved or at least that I can see.
    Remove them adn scuff with scotch brite or light sand paper maybe??
    Still hoping the GOV'T will ban the use of loud stereos with RAP music. [​IMG]
    <a target="_blank" href=http://www.mccords.s5.com/myk5/index.htm>NashvilleK5</a>
  2. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    I had that happen on a recent brake job myself after about a week. Pulled the wheels and calipers and hit the rotors lightly with a fine wire wheel in a circular pattern. Not a sound since then...
    Haze gray and underway...<font color=blue>or blue, in my case.</font color=blue>
    <a target="_blank" href=http://community.webshots.com/album/26246038MbQsYWKcbo>U.S.S. Nimitz II</a>
  3. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    If you notice on the pads themselves when the caliper is installed, you will see these 2 ears (what I call them) that stick out and rest on the caliper. Well if these guys arent holding the pad tight against the caliper then you'll get the squeaking.
    You take a screw driver or small pry bar and put that on the bottom of the pad in between it and the rotor. Pry the pad upward and hammer those ears downward. That will keep the pad tightly fit on the caliper and stop the squeal.
    Crawlin the rocks with my K5
    <a target="_blank" href=http://www.rockreadyk5.com>http://www.rockreadyk5.com</a>
  4. Fierospeeder
    Fierospeeder Banned
    Sep 17, 2001
    315
    Illinois
    pull your wheels off, and inspect to see if theres any overheating on the rotors. Usually black areas.
    if you got the money, you can get your rotors "cut" at nappa, or pepboys for around 10-12 bucks.
    pepboys does have the kit to deglaze the rotors using a powerdrill, or a grinder.
    another cause is brake dust, you can buy a can of brake clean and spray the area.
    74 VW Beetle
    84 Pontiac Fiero
    87 Ford Thunderbird Turbo
    83 Honda Nighthawk 550
  5. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    and they dont squeal while not braking....And I tried the spray cleaner stuff. But I thought it was coming from up front. But have since found that it may be coming from the rear driver-side after cleaning all the mud out from being barried for 2 days. So I'll get out there and spray some in the dust holes while rotating the wheel and see what that does.
    You all know of anywhere to get the disk brake caliper guide/mounting bolts for the front? LMC cat doesn't show them and Im sure the dealer is way too high on them.
  6. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Check this out. My grandfather is an old brake guy from a Dodge dealership here in town and he tells me to take hand full of AJAX or Comet and throw in the drum. Said that will stop the squeeling. Anyone else ever heard of this? Sounds like jerry riggin to me but if it doesn't hurt anything and works, hell!! I dont see why not.
  7. Fierospeeder
    Fierospeeder Banned
    Sep 17, 2001
    315
    Illinois
    usually most auto parts stores carry the hardware such as the bolts and the seals. The caliper bolts are overpriced in some areas.
    ask the behind the counter guy if they have a kit with the stuff you need.
    I usually go to the junkyard and pull bolts off the calipers which are usually free compared to 10-20 bucks at the car parts store.
    74 VW Beetle
    84 Pontiac Fiero
