BRAKES!!!!squirrly, gear heads please help
Discussion in '1992-Present Chevy & GMC models' started by trailromper, Jan 8, 2003.
  1. trailromper
    trailromper Registered Member
    Jun 16, 2002
    13
    Colorado
    When I step on the brakes, my '94 blazer 1500 will pull to the right what is causing this. I have a hard time keeping it straight when i step on the brakes. /forums/images/graemlins/1zhelp.gif
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    Check your front brakes, right side could be grabbing, or left side might not be working, either situation could make it pull right. It could also be suspension related, something worn or loose allowing the suspension to shift under braking and causing it to steer right.
  3. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    Check the air pressure in the tires, if you have access to the rotors, check to see if they are grooving from the pads...if you just did a break job on them did you get the kit from Chevy? It has new o-rings and grease to get the job done right /forums/images/graemlins/k5.gif
  4. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    What type wheels on it.I used 10's for a while and they were rough on the wheel bearings.Would cause low pedal on first pump pulled any direction, not like caliper sticking which acts the same each time stopping.Changed to older 8 inch rally wheels and ended bearing trouble,except for getting mud in them.Just can't seem to stay out of it for some reason. /forums/images/graemlins/crazy.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
