BRAKES STUCK?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Poohbair, Mar 6, 2003.
  1. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I recently towed a 80 Jimmy home that had been parked for over 10 years. On the tow home the guy I was towing stepped on the brakes and they stuck on /forums/images/graemlins/eek.gif? What do you think this probably is, and the CHEAPEST way to fix it? I don't want to redo the whole brake system... Im thinking maybe master cyl or wheel cyl?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Well, since it sat for so long, first start by tearing apart the drum brakes and calipers. There's a good chance the calipers didn't return to the open position once the pressure was let off because the piston got stuck. Likewise, the springs and stuff in the drums out back could be stuck too.
    There are so many possiblities (like you said, wheel cylinder and master cylinder) so it's hard to say for sure. Start with the calipers and drums. /forums/images/graemlins/thumb.gif
  3. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I will have to do that, thanks. Driving w/ the brakes on would kill my fuel mileage when I get the new motor put in!
  4. heavy4x4
    Aug 28, 2002
    3,270
    That and it would create so much heat you'd be warping rotors and drums left and right. /forums/images/graemlins/shocked.gif
  5. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    Hey POOH
    I dont really dont like being referred to "THE GUY I WAS TOWING" i have a name you know..... /forums/images/graemlins/shocked.gif
    BRAD
  6. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Yeah, but nobody here knows your real name.... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
    OK everybody...I was towing BRAD and he messed up my brakes... /forums/images/graemlins/wink.gif
  7. heavy4x4
    Aug 28, 2002
    3,270
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif There, how's that for recognition. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  8. Grim-Reaper
    7,385
    Atlanta
    Brakes and Cheap should never beused in the same sentence. If it sat for 10years I would seriously concider replacing EVERYthing but the hard lines. I would blow them out and start with freash fluid. Turn the rotors, prepalce the calipers, wheel cylinders and pads. I wo0uld also concider replacing the master. SITTING IS BAD for vehicles. I would also pull the diff coveras andm ake suth the ring and pinions are not covered with rust.
  9. white-rhyno
    Jan 27, 2002
    942
    Thanks POOH, i feel so much better now that im recognized.
    Two Days Till The Swap Meet!!!!
  10. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I spose he is right. The half of the ring gear that is not submersed in oil could be rusty.
