BRAKES????WHAT BRAKES??!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5RANGER, Apr 11, 2001.
  1. K5RANGER
    K5RANGER Registered Member
    Feb 1, 2001
    21
    NORTH CAROLINA
    LONG STORY....LOST BRAKES, SCREWED TRANSMISSION!
    HAD TO SLAM TRANSMISSION INTO PARK TO KEEP FROM GOING INTO MAJOR TRAFFIC WHEN ONE BRAKE LINE EXPLODED. NOW.......I CAN CHANGE GEARS MANUALLY BY TURNING KNOB ON THE TRANS,. HOUSING, BUT NOT WHEN LINKAGE IS CONNECTED. I CAN SEE NO EVIDENCE OF BINDING IN THE OUTER LINKAGE, CAN THERE BE A PROBLEM IN THE COLUMN? THE SHIFT INDICATOR DOESN,T READ CORRECTLY NOW..IT SHOWS NEUTRAL WHEN I'M IN REVERSE. THE TRANS. WILL NOT GO PAST NEUTRAL W/OUT GIVING IT A FIGHT, AT WHICH TIME IT WILL GO ALL THE WAY TO LOW 2 THEN WORK UP TO DRIVE. I'M NOT FAMILIAR WITH STEERING COLUMNS OR THEIR GUTS..AND BEFORE I FIND OUT HOW MESSY IT CAN BE, I THOUGHT I'D SEEK SOME ADVICE, HELP, AND/OR FREE THERAPY.
    THIS IS A TH350 IN A 78 K5<P ID="edit"><FONT SIZE=-1>Edited by K5RANGER on 04/11/01 05:58 PM (server time).</FONT></P>
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    There is a clip on the column that rotates with the column and moves the indicator needle. Just move the clip tot hte left and it will be fixed...thats the smallest of your problems now though...
    90K5
  3. im_2gr82h8
    im_2gr82h8 Registered Member
    Apr 4, 2001
    91
    federal way, washington
    I feal your pain!!!!! I just blew out 2 rear wheel cylinders and broke my front passenger side rotor colpletely off! It was just hanging on the axle. :) At least you had 2 brakes to stop with, I only had 1.
