BRAKES... what do I order??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by StiffRide81, Sep 18, 2002.
  1. StiffRide81
    StiffRide81 Registered Member
    Aug 24, 2002
    53
    Tinley Park, IL
    Hey my K10 has a 10 bolt in front (stock) and a 14bolt SF in back... my question is.. when I go to order brakes on it... what do I ask for... the rear-end is not stock... Juat curious!!
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    That depends. Is the SF 14B a six lug or eight lug?
    Eight lugs are 13" brakes
    Six Lugs are 11" brakes.
    The eight lug brakes can be found for a 1985 3/4ton 4WD suburban should work.
    Six lugs are a little tricky. they never offered in the 73-87 body style. But can be found under 88-98 trucks. Look for a 93 2500 Light duty truck. SIx lug application 2wd.
    Hope it helps,
    John
