brakes?
Discussion in 'The Garage' started by nicotine, Sep 25, 2004.
  1. nicotine
    nicotine 1/2 ton status
    Jan 11, 2004
    116
    was driving the other day and all of a suden my brakes started to pull hard to the right when i apply preasure. i locked them up to check it out and only one side locked the passengers. what would cause my brakes to do this all of a sudden? also sometimes i can hear my drivers side brake sqeek with each rotation? /forums/images/graemlins/1zhelp.gif
  2. trikstark5
    trikstark5 1/2 ton status
    Feb 17, 2004
    169
    usa
    The pulling to the right sounds like you have a caliper hanging up or going bad. The squeaky of the brake pads could be the indicator on the pads... /forums/images/graemlins/k5.gif
  3. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Your caliper has seized. Replace the pass side caliper and you should be fine. I had this same problem but it was my driver side.
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I agree with Tristar. It sure sounds like your caliper is siezed shut. This would be a good opportunity to replace the calipers and pads and turn your rotors.
    The caliper job is pretty easy, and if you are mechanical enough to take your own rotors off the truck, most shops will turn the rotors for a few bucks each.
    Make sure you take the time to check your brake lines while you're under the truck, brother.
  5. diesel4me
    Jul 24, 2003
    17,537
    923
    Massachussetts
    Could be a bad rubber brake hose too--my van did the same thing,I assumed it was the calipers so I got rebuilt ones--it felt ok on the test ride after installing them,but the brakes started pulling and locking the next day on my way to work--a mechanic friend told me to loosen up the bleeder screw after jacking the tire off the ground--if that releases the brake--its the brake hose that has failed internally,acting as a one way valve--lets pressure into the caliper,but wont let it flow back to the master cylinder and release.If the brakes are locked still after opening the bleeder,its the caliper seized its piston,or is sticking on its bolts and slides. /forums/images/graemlins/crazy.gif
  6. nicotine
    Jan 11, 2004
    116
    shouldnt it be the drivers side calipier i have to replace since it has no preasure?
