brakes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KENNY, Apr 12, 2001.
  1. KENNY
    KENNY 1/2 ton status
    Dec 7, 2000
    292
    nyc
    I HAVE A 84 BLAZER WANT TO CHANGE FRONT BRAKES,CALIPERS,ROTORS,LINES. WHAT SHOULD I LOOK FOR? UPGRADE? PROBLEMS I MIGHT HAVE?
  2. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    You'll need the special hub socket to get the rotors off. Other than that, it's pretty straight forward. Any repair manual covers it pretty well. Might as well inspect/change wheel bearings and that little bearing that the sub axle rides on along with the seal on the back side. Get the highest quality aftermarket rotors, pads, calipers you can. Brakes is one area you shouldn't try to safe a couple bucks, esp. if you have oversized tires. You can get longer brake lines for when you go to a lift if you haven't already. NAPA has them, but you'll have to find a helpful counter person and should take your old line in to make sure the ends are correct. Also inspect the axle u-joint at the hub and replace that if worn. Since you have it all apart, might as well take care of everything. Oh yeah, some of the guys run marine grease in the wheel bearings.
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    ditto on the brakes. I spent over two month trying to figure out why my front brakes were not locking up. turned out to be the pads, I got some cheapies that crumbled apart.
    ARQ.
  4. Chewy
    Chewy 1/2 ton status
    Sep 4, 2000
    197
    Parker, Colorado, USA
    The outer casing of the hub and the rotor are two seperate parts. You will need to get the hub part machine pressed off the rotor and then re-pressed onto the new rotor. It cost me $20 to do this about a week ago. If you are buying new brake lines, you might as well get steel braded brake lines. I got Pro Comp lines from 4 Wheel Parts online. They cost about $100 with shipping and I got them in 3 days. It you have any questions when you are doing the job, PM me and I should be able to help. I just did the whole job last week.
    '87 Beast
    Colorado, USA
  5. KENNY
    Dec 7, 2000
    292
    nyc
    you were right about the machine press, does this mean that these are the originals? 4x4 a little bit of a pain. did a convert job on my nova that went much smoother than this.
  6. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>You dont need a press, just a brass drift, BFH and someone to hold it. Thats how I switched the rotors on my 8 lug 44 and mounted the rotors on my 14 bolt.</font color=blue>
  7. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    What rotors did you mount on your 14 bolt?Is there some group of factory parts that can be worked together to have a rear disc brake setup on these monsters?
  8. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>TSM brackets, F250 rotors, cadillac eldorado or stock GM 4x4 front calipers. Check my site for pictures, its in my profile.</font color=blue>
