Brakes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bandit, Jun 13, 2001.
  1. bandit
    bandit 1/2 ton status
    Mar 4, 2001
    690
    Ellensburg Washington
    OK i need help Ever time i hit my brakes it pulls really hard to the right what is cousin this?? i tried bleeding them and that helped a little but not much no i need to try bleeding them some more or what??
    AJ
    Soon to wheelin spot near you
    Project Harvey[​IMG]
  2. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Either the right side is grabbing too hard or the left is not grabbing (or too weak). Could also be bad balljoints on the right.
    Rotors smooth on both sides? New pads seated correctly? It could be a siezing caliper on either side, not wanting to move too much. Also, hose could be collapsing, making it work like a check valve.
    Take off the calipers and try to compress them with a C-clamp or something. If one goes real easy and the other doesn't, caliper or hose is causing you problems. Make sure the rotors are smooth too.
    Ratch
    **<A target="_blank" HREF=http://k5.8m.com>http://k5.8m.com</A> What more is there to life?**
