BRAKES!!!!!!!!!!!!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Sep 7, 2001.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    I cant stand living in a small town anymore I CANT FIND ANY TOOLS I NEED!!!!!!!!!!!!!!
    Just needed to get that out.
    Ok besides using the hex bit what else can I use to unbolt the calipers on my 85 jimmy?
    1985 GMC JIMMY
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I wouldnt reccomend useing them, but you could use Visegrips but those bolts should be really tight. Any hardware store or parts store should have Allen wrenches. (The hex tool) If youre really stuck, Id even give your a 3/8 allen because you probably wont get it out without one.(I can get them from work!)
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    If worse comes to worse, you can get a 10-24 "rod connector" (looks like a really long nut - costs about 75 cents at the hardware store), and stick it in the bolt, and use a 3/8" wrench to turn it.
    1 tequila 2 tequila 3 tequila Floor
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  4. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    Cheater bar!!!!!!!!!!!!!!!hehehe.
    Neil H.. Alabama.. '78 K5 400ci 4x4 AT,AC,PW Cheyenne. '74 C10 3spd/floor 250ci 4x2
  5. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,259
    71
    Humboldt/Pacifica, CA
    Square stock ground down on the 4 corners if you're hardup [​IMG]
