Brakes ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by HispanicPanic, Jan 31, 2002.
  1. HispanicPanic
    HispanicPanic 1/2 ton status
    Mar 21, 2001
    351
    El Paso, Texas
    Hey Guys/Gals sorry ive not been around lately its cuz i dont have the net anymore, anyway i just got a hold of Scoobydann PC and now I have a question to ask. The problem is i cant get enough pressure in my brake pedal my pedal is too soft im tring to bleed my brakes and it just wont get stiff after pumping it, the reason im doing this is cuz i changed my proportioning valve. THANX
    <font color=purple>I put the Panic in Hispanic</font color=purple>[​IMG]
    <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
  2. Master cylinder may be bad, or you have a lot of air trapped in the lines from changing the prop. valve. You may try opening all the "zerks" and let it bleed for a day and then closing them and bleeding them as normal. Sorry I can't be of any more help.
    Alcoholism isn't a problem, it's a GOAL!!!!!!!
