Brakes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Adub, Jan 25, 2003.
  1. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    New calipers, Wagner Thermoquiet pads, rotors, and brake fluid. I bled the brakes for over an hour. No air coming out. Pedal is fine, truck stops decently under light pressure. But if I kick it had, its squishy and won't lock the wheels up? I am going to have to go get them vacuum bled?
    Aaron
  2. dremu
    Feb 27, 2000
    15,951
    440
    East of San Francisco
    Re: Brakes -- hoses?
    If the hoses are old, they'll expand when you whang on the pedal, and your pressure is lost to making them blow up like balloons /forums/images/graemlins/frown.gif
    When I redid my '77 recently, I replaced all three of the soft hose sections (left, right, center rear) -- wasn't too much more $$ than I'd already spent on rotors, calipers, etc, and the old ones were pretty scary after 20+ years in the Las Vegas desert heat /forums/images/graemlins/smile.gif
  3. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    The hoses looked good. I checked them visually under pressure and they didn't expand noticeable.
    Aaron
  4. dremu
    Feb 27, 2000
    15,951
    440
    Could be leaky master or booster, then. I don't have any scientific method of checking them -- when I did the '77 I upgraded to the later style master, with the bigger piston, so I had to get the later booster to match.
    -- A
  5. Grim-Reaper
    7,385
    Atlanta
    Did you turn the rotors?
    Pads need to seat and on fresh turned rotors they seat much faster.
    Drive around and make a few hard stops and ride the brakes HARD at low speeds to get the pads to seat. If you have unturned rotors and they have slight gooves of even a couple thousanths of an inch then your not getting full pad contact. You may be getting as little as 25% pad contact till the pads wear into the rotor.
  6. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    Brand New Rotors and new pads. I am going out right now to bleed again. I will try the seating the pads idea.
    AW
