brakes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dylanzr1, Apr 6, 2003.
  1. dylanzr1
    dylanzr1 Registered Member
    Nov 5, 2002
    5
    Arizona
    does anyone know where I can find a front brake CALIPER MOUNTING BRACKET/BACKING PLATE or whatever it's called for an 86 k-5 blazer 4x4 I have checked dealer, napa, all the usual supects including salvage yards in the area. no luck at all. the blazer pulls hard to the left when you hit the brakes. i replaced calipers/rotors but there is a caliper bolt that won't tighten up so i think the brackets threads are stripped causing the caliper not to engage all the way. any help on this subject would be greatly appreciated.
  2. ed1507
    ed1507 Registered Member
    Jan 25, 2003
    70
    indiana
    u could try retaping it and replaceing the bolt might be a little cheeper /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  3. dylanzr1
    Nov 5, 2002
    5
    Arizona
    yeah I might have to try that thanks.
  4. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    If you are talking about one of the two pins that hold the caliper on..... there is an aftermarket replacement that is oversized to fix a stripped unit. Thay are about $10-$15 & work rather well. Look on some of the "HELP" racks located in many autoparts stores.
  5. dylanzr1
    Nov 5, 2002
    5
    Arizona
    thanks lonnie I did not know about that. if I can't find them do you stock them in your parts store?
