braking problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by coreyd, Sep 2, 2004.
  1. coreyd
    coreyd Registered Member
    Mar 24, 2004
    76
    San Mateo, CA... from South Dakota
    I have a (90 burb 3/4 ton with 6" lift and 37's, while braking it wants to pull to the right severe, I have to crank the wheel to the left to counter act, this occurs at all speeds, is there a correction that I can do to fix the problem.
  2. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Just gotta check all the obvious stuff -ball joints, steering linkage, air in brakeline, sticky caliper, sloppy wheel bearing, unusual tire wear. Sounds dangerous though.
  3. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    warped rotor, or a bad caliper
  4. Catman
    Catman Registered Member
    Feb 4, 2003
    53
    Yucca Valley, Calif.
    Got the same problem in my 90 K5. Looked at all the obvious stuff and still don't have a clue. If you find something, PM me and let me know.
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/confused.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Make sure your wheel bearings aren't loose and CHECK YOUR BRAKE HOSES!!!!!!
  6. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
  7. oh2dive4
    oh2dive4 Registered Member
    Aug 7, 2004
    7
    Had a similar problem, turned out to be a sticking caliper. Be certain that the calipers will slide in the brackets as designed.
    Fighting to keep out of the ditch while stopping is no fun.
  8. rooferbret
    rooferbret 1/2 ton status
    Dec 26, 2003
    265
    Sacramento,CA
    I also had the same problem. I replaced both calipers and bolts. no more pulling! /forums/images/graemlins/waytogo.gif
