braking woes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by stevewix, Jan 5, 2005.
  1. stevewix
    stevewix Registered Member
    Dec 2, 2004
    83
    hi all, i've got an 85 m1009 cucv that i recently swapped 1 ton axles onto. i thought it braked weird before, swapping the axles confirmed my suspicion, the rear brakes aren't getting any kind of pressure. i can't gravity bleed them, it acts like the line is kinked or the proportioning valve is screwed up. i'm 99% sure they never worked right from day one, so i would rather inspect master cyl, etc.
    the rear has a new pro-comp brake line, so the rubber one isn't collapsed or anything.
    ideas? questions? post up!
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Are the lines kinked?
    I had a pain in the ass braking problem and went through 3 masters. I broke off a fitting on the MC and replaced the hardlines to it, and it seems to work fine now on stands
    You can try gettin a used master so you can start throwing parts at it, I got them from members for cheap cheap
  3. stevewix
    Dec 2, 2004
    83
    hey thanks, after bleeding the brakes 4 TIMES then using a suction bleeder i finally got an enourmous air pocket out of the systemworks!
  4. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Hooray!
    I fell out of my truck last time I bled brakes
    Three feet to concrete
