brand new trans won't shift
Discussion in 'The Garage' started by 85 Jimmy, Nov 18, 2006.
  1. 85 Jimmy
    85 Jimmy Sheepdog Premium Member
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    just got finished putting in my crate motor and new tranny from TCI, the problem is when i put the tranny in gear it won't move. i ran it through the gears to get the fluid in the clutch packs and in the new torque converter and then made sure the trans was full and it was. i did put bolt in the torque conveter so thats not it.
    if i don't get any helpfull hints by the morning i'll just end up calling TCI (which i'll probably do anyway)
    thanks for any help
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    What tranny is it? How much tranny fluid did you put in?
  3. savagek5diesel
    savagek5diesel 1/2 ton status
    Nov 20, 2003
    310
    Redding California
    with a new tranny and torque conv. it will take a lil' bit until you grab a gear pretty solid. just my personal exp. though. i used alot more tranny fluid than expected w/ my rebuilt trans and new tq. conv.
  4. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    did you fill the convertor before you installed it?
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    did you adjust the tv cable? after we put another 700r4 into a buddies k5, it was terrible cuz the tv cable wasnt adjusted properly.
  6. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    If you didn't fill the TQ converter you probably fried the pump.
  7. 85 Jimmy
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    i got it done...
    last night i just shifted it through the gears a few times, today i rechecked the fluid and it was alittle low so i filled it then shifted through the gears... i kept doing that until i filled the tranny with around a total of 1o quarts of fluid
    i found out earlier today that it's really fun to scare the **** out of someone when you idle up next to them and bump the throttle with open headers :D
  8. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i love doing that :)
