brass or plastic float
Discussion in 'The Garage' started by wazzabie, Aug 27, 2005.
  1. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,721
    11
    Washington State
    I've been tearing into several carbs I have had around and I found that on has a brass float and the other a plastic. This is for a 77 and 78 quadrajet with out eletric choke. What is prefered? Can I swap floats?
  2. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    switch to brass if possible.
  3. rumbly truck
    rumbly truck 1/2 ton status
    Jul 4, 2005
    132
    utah
    Use a brass one. Brass floats are easy to tell if they leak, or if they get heavy. A plastic one you have know idea. The plastic one can absorb fuel while in use, and raise your float level. You can take it out to check, the gas will evaporate, and you still wont know.
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I prefer brass for the same reasons mentioned above
  5. wazzabie
    Apr 17, 2001
    1,721
    11
    Washington State
    Would I be able to interchange the brass float from my 78 qjet to the 77 qjet? How di i know that the are comparable? Both share the the numbers 17058213 and 17057213
  6. diesel4me
    Jul 24, 2003
    17,570
    943
    Massachussetts
    Use brass if possible!
    Brass ones resist alcohol and fuel additives much better than foam floats---I can look up the # for you and post back tomorrow,if that will help you.. :crazy:
  7. wazzabie
    Apr 17, 2001
    1,721
    11
    Washington State
    Please do.
    I have a brass float for 17058213
    the plastic float is for 17057213
  8. diesel4me
    Jul 24, 2003
    17,570
    943
    Massachussetts
    Darn!!
    I wrote your # down wrong!--but 17057215 and 17058215 are the same float-(I wrote down a "5" instead of a "3"! :doah: )-I'd assume the 17057213 and 17058213 use the same float too--but I'll check again in my book (it out in my shop!)..and get back to ya..might not be until later tonight or tomorrow before I go back to the shop though.. :crazy:
    Actually,only 2 # of floats fit 90% of all Q-jets..and they look very different..but its best to use what the book says,just in case.. :crazy:
  9. wazzabie
    Apr 17, 2001
    1,721
    11
    Washington State
    Thanks.. looking forward to the info.
  10. wazzabie
    Apr 17, 2001
    1,721
    11
    Washington State
    I'm still hoping that you might share the data.
  11. diesel4me
    Jul 24, 2003
    17,570
    943
    Massachussetts
    Sorry!
    :doah: :blush: --I forgot to look up your info!--I'll look tonite and post back ASAP--might be tomorrow before I can get online again..sorry !!..I'll get you the Standard/Hygrade brand part # and also the # for a carb kit and choke pull off,and accelerator pump.. :crazy:
    Maybe I should just bring my catologs in the house!--seems I need them in here more than in my garage since I got the computer!... :p:
  12. diesel4me
    Jul 24, 2003
    17,570
    943
    Massachussetts
    Here U go!
    Both the 17058213 and 17057213 carbs share all the commom parts..(1977 and 1978 carbs,according to the listing in my catolog)..
    Standard/Hygrade part #s are:
    "Jiffy Kit"-- 1585A
    "Float" -- FL-1
    "Choke Pull Off "-- CPA-439
    "Choke Thermostat" -- CV-204
    "Accelerator Pump" -- R64-335
    Sorry I took so long!..got sidetracked over the holiday!.... :doah: :crazy:
