Break in after valve job?
Discussion in 'The Garage' started by rafterman191, Dec 1, 2006.
  1. rafterman191
    rafterman191 Registered Member
    Aug 28, 2006
    54
    Indiana
    I just installed my heads after getting them back from the machine shp. I drove it around town a couple days, maybe 50 miles and kept it under 46 mph. Yesterday coming back from my grandmas house, I was going between 50-55 mph for abut 10 miles. When I finally slowed down,there is a loud knock coming from the block. Sounds bad. Did I not give it enough time to get broke in, or could wrongly adjusted valves be to blame?
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    did you change the cam? that's the only "break in" required. your rockers may just be out of adjustment.
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,993
    130
    Did you replace the rocker nuts? A loose rocker could be pretty loud. They need to be replaced every time the rockers are removed (they are jam nuts).
  4. rafterman191
    Aug 28, 2006
    54
    Indiana
    No, I just reused the nuts. They aren't the type w/ locks, they are off of a '86. Very good points though that it could be rocker adjustment. Giving me hope.
  5. 1977k5
    May 26, 2003
    9,993
    130
    The lock nuts wear out. They are only designed to be used once.
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    wow, i wonder why all the motors i have worked on are still running then :doah: :p:
  7. 1977k5
    May 26, 2003
    9,993
    130
    Its not so much that they are really one time use, they just become less effective after each removal/install. I reused mine and after having to pull the rockers a couple times (broken valve springs) the nuts started coming loose.
    It could be his problem and it could be something worse.
  8. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Well, yeah, i can understand if you remove them several times, alot of components wear out like that, but to say they are only meant to be used "once" It's not a bad idea at all to replace them, but you can use them again. Just don't get crazy with using them again and again and again and again,,,,,,,,:D :p:
  9. rafterman191
    Aug 28, 2006
    54
    Indiana
    Update:
    I readjusted the rocker arms. Didn't help. I am believing it is unrelated now (kinda unrelated). The noise almost souns like an exhaust leak, just to give you a noise to relate it to. It gets alot louder with the tranny engaged and during acceleration. Like combining the sound of an exhaust leak with a loud engine knock. Sucks whatever it is. Could it be a bell housing problem?
  10. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Sounds like your flexplate is cracked bro.....RnR
  11. rafterman191
    Aug 28, 2006
    54
    Indiana
    Interesting. Will do some digging.
  12. rafterman191
    Aug 28, 2006
    54
    Indiana
    Could this possibly accompany some tranny fluid leakage? As it seems I have suddenly found a good amount of it on the bottom of the tranny, pan etc.
