break out the thinking caps and crystal balls
Discussion in 'The Garage' started by purple76pearl, Oct 20, 2003.
  1. purple76pearl
    purple76pearl 1/2 ton status
    Jan 13, 2003
    450
    missouri
    ok so back in the day dad always told me dont fix it till its broke
    well awhile back i made a post about a pop and crack in my front end (dana 44)
    well i ( after long inspection, 2 weeks) decided my tires were too wide, go cross over
    so i finally got the knucle machined, and new ball joints put in and ready to install, 4 days ago
    put it in, and started driving it with only knucle put in, because of other probs with cross over stuff, but anyway
    so im driving it, with only changing the knucle
    and i have a huge vibration in the rig now
    seems to be in the front end, but dotn know what it would be
    ball joints are new
    tir rod ends are good
    i cant figure it out
    any suggestions
  2. big d
    big d 1/2 ton status
    Oct 24, 2001
    1,236
    illinois
    front tire maybe need rebalanced ? i gotta do the same soon with mine, lost wheel weights, i got vibes to. /forums/images/graemlins/blush.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/ignore.gif /forums/images/graemlins/rolleyes.gif
  3. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    is there a shimmy in the steering wheel?
  4. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    I don't know from nuthin but since you put in new parts and what not have you checked the alignment?? That could make for a brand new vibration. Just my .02 worth. Good luck to ya.
    Allan
  5. purple76pearl
    Jan 13, 2003
    450
    missouri
    why would tire all of a sudden get out of ballance? no weights on out side of tire?
    shimmy really bad in steering wheel
    dont think its out of alignment, kinda hard to get sfa thatfar out of wake i think,
    but i could be wrong
    i will sure check off of these thanks guys, keep em coming
  6. When you put in the new ball joints did you preload the adjusting nut correctly? If you didn't then the upper ball joint will become lose and cause a vibration.
  7. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Did you check the steering box were it mounts to the frame?
  8. purple76pearl
    Jan 13, 2003
    450
    missouri
    OK, THIS IS AN UPDATE
    IM AM A STUPIDO <- I JUST MADE THAT UP
    I FINALLY BROKE DOWN, SPENT 4 HOURS OF SWEAT, TEARS, AND BEER,( I USALLY DONT DRINK) AND TORE IN TO MY RIG
    I TOOK EVERYTHING APART, (FRONT END, REAR DIVE SHAFT, T-CASE, AND UN BOLTED TRANNY) FINDING NOTHING I SEEN THAT WAS WRONG
    BUT WHEN I PUT IT ALL BACK TOGETHER ( I MEANING ME AND MY EXPERT MECHANIC I FOUND THAT DID MOST OF THE WORK) NOTHING WAS WRONG, POP WAS GONE IN FRONT END, NO VIBRATION, HELL IT RUNS BETTER THEN IT EVER HAS
    SO IN CONCLUSION
    WHEN IT DOUBT, PULL IT OUT, AND SLAP IT BACK IN /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif HAHAHAHA
