Break problems after 1 ton swap.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by crazy_swede_73, Apr 12, 2004.
  1. crazy_swede_73
    crazy_swede_73 Registered Member
    Jan 16, 2004
    76
    Stockholm, Sweden
    I bet you've heard this before,,,
    During the axle swap the MC got dry, so i figured i'll try and gravity bleed the system ,,,,with no luck! i still had spongy pedal and rear breaks locking up, so i tried bench bleeding the MC ,,again same thing, bought a new MC bench bled it and ,,same thing,,,
    Rear locks up before front and spongy pedal.
    I tapped on and bled the combination valve but it didnt help i still have bad preasure to the front breaks.
    I'm thinking bad combo valve,,,???
    Crazy_and tired of break fluid on my hands_swede
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I had the same situation when I did my 3/4ton swap the other weekend. I ended up having to get it pressure bled. All fixed now /forums/images/graemlins/thumb.gif
  3. crazy_swede_73
    Jan 16, 2004
    76
    Stockholm, Sweden
    I think i have to try that, i'll just drive down to my friend's shop and give him a couple of those green monsters (heiniken) and say hook me up ,,,,and if that doesn't work,,?,,
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I have had the same problem.Did ya try again after your drive?After mine wouldnt gravity bleed and I still had a spongy pedal,I drove it around a bit and tried it again.I was able to get the rest of the air out after the short drive /forums/images/graemlins/grin.gif
  5. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Might try some speed bleeders, I just picked up a set for 24 bucks for all 4 wheels and I think theyll work, I think they worked fine for Jay Pee
  6. crazy_swede_73
    Jan 16, 2004
    76
    Stockholm, Sweden
    Nope,,,i drove around for an hour,, still spongey /forums/images/graemlins/mad.gif,,,i'm changing that valve,,,
  7. crazy_swede_73
    Jan 16, 2004
    76
    Stockholm, Sweden
    News flash,,,,,
    I think i found a bug /forums/images/graemlins/tongue.gif
    A guy at work told me that if you mix up the calipers and mount a caliper on the wrong side, you will have the bleeder screw at the bottom of the caliper.Wich means that the air thats inside will never come out, i just checked (retard) AND the bleeders screws IS on the bottom of the mthafokkin caliper,
    /forums/images/graemlins/hack.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/dunno.gif
  8. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    check your calipers and make shure they are not swapped, ask me how I know /forums/images/graemlins/ignore.gif
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I know that on mine, I have the caddy calipers in the rear, and in order to put on the ebrake kit, you have to have the bleeder screws down /forums/images/graemlins/shocked.gif
  10. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    /forums/images/graemlins/histerical.gif
    Marv
  11. crazy_swede_73
    Jan 16, 2004
    76
    Stockholm, Sweden
    ohh yes,, they were swapped /forums/images/graemlins/shocked.gif
    I put them where they should be and tought hey this is gonna work /forums/images/graemlins/tongue.gif NOT.
    I guess that i just have to get that valve ,,i think /forums/images/graemlins/eek.gif
    The only problem is that where i live, US parts aren't that cheap,,so that valve is somewhere around $110 ,,sucks.
  12. Ben
    Ben Registered Member
    May 3, 2002
    96
    Pick a country in SE ASIA!
    So... should the bleeder screws always be on the top or bottom? Any opinions? Doesn't matter?
  13. crazy_swede_73
    Jan 16, 2004
    76
    Stockholm, Sweden
    It should always be on top.
  14. crazy_swede_73
    Jan 16, 2004
    76
    Stockholm, Sweden
    problem solved /forums/images/graemlins/laugh.gif
    It was the combination valve,,after bleeding the system ,,,AGAIN /forums/images/graemlins/rotfl.gif´the truck stops like never before /forums/images/graemlins/waytogo.gif
  15. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    Congratulations! So was your truck 1/2 ton originally? What m/c, combination valve, and rear calipers are you using? Do your rears still lock before the fronts? /forums/images/graemlins/ears.gif
  16. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    /forums/images/graemlins/woot.gif /forums/images/graemlins/waytogo.gif
  17. crazy_swede_73
    Jan 16, 2004
    76
    Stockholm, Sweden
    Thanks!!
    Yes its a K5 ,,so i bought k5 stuff, the MC an Valve was AC delco,
    Front locks before rear /forums/images/graemlins/peace.gif Hard!
    I dont have rear disc's yet /forums/images/graemlins/grin.gif, maybe next year. /forums/images/graemlins/thumb.gif
  18. crazy_swede_73
    Jan 16, 2004
    76
    Stockholm, Sweden
    Cool!!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
