breakage
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by swampers83, Jun 22, 2000.
  1. swampers83
    swampers83 Registered Member
    Apr 2, 2000
    13
    Texas
    My bud and i were out wheeling and he has one tough setup. Dana 60 front and a 14boltFF in the rear both detroit locked and 5.13 geared. Anyways, i thought his drivetrain was bulletproof. However, while climbing a hill (not too big but fairly steep) his front axle shaft broke right in half!! on a dana 60? Also he only had 35" BFG all terrains w/ no tread left. I guess my question is that even if you have a big axle can it become weak if it is old? THANKS!
    chevy-like a rock
  2. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    No
    Unlike human bones that get old/weaker with age, axles remain there strenth over the usefull life.
    unless you over stress them.
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Did the actual shaft break, or was it the u-joint that broke?
    Concerning metal parts getting weak over time, yes they can and yes they do. Any time a part is contantly undergoing varying torque loads you will experience fatigue of that part over time and it will eventually break. The harsher the torque loads are, the quicker the material fatigues and will fail. In other words, if you contantly run the %^&% out of a truck you can break anything, a heavy duty part might just take a few more tries. If you run the truck easy, it might take 100 years to fatigue an axle shaft to break, if you run it really, really hard...it might take two days.
    Executioner, since I know you will ask this, if you want facts go buy a "strength of materials" book or a machinery design handbook.
    P.S. - you did get me on the Gov-Lok/additive topic.
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
  5. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Executioner...I think you're the only guy on CK5 that takes joy in correcting people. Chill out. There is a difference between educating someone and making them feel stupid.
    '73 K5
    Chevy good...Ford bad
  6. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    Not all 60 axle shafts are the same-early years had a shaft that was just slightly larger than a 44's. I've seen front housing that had so much mud and water packed inside that the shafts were rusted down with deep pits and I know that had to weaken them somewhat.
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've seen several axles break on what would seem to be "easy" trails. It seems that you can twist or crack an axle shaft on a really hard run and it might take a little more abuse before it finally breaks. The crack could have been there for months.
    A friend with a 500 ci, fuel injected Scout broke an axle while idling up a nice easy section of rocks. It had taken LOTS of abuse from that engine on previous runs. [​IMG]
    http://ThunderTruck.ColoradoK5.com
