Breakaway battery charging
Discussion in 'Tow & Trailer' started by FWP, Sep 12, 2004.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Can I use a regular battery charger to trickle charge it overnight? This is what I have, but no charger...
  2. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    Fred,
    Yes you can. Once you hook it up to the trailer, make sure that one of the wire is a direct 12 volt feed, as when the trailer is hooked up to the tow rig, it will charge the battery. When it's disconnect it looses charge.
    The 7 pin connectors have an extra/aux wire for 12 volt feed, for when it hooked up to the tow rig. Just make sure you use a heavier gauge wire for the Aux feed.
    Rob
  3. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Thanks. I've heard that leaving that little battery hooked up to the tow rig that way will ruin it /forums/images/graemlins/dunno.gif, and most people use a little charger you can get from Tekonsha or Hoppy.
  4. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Just charge it up- Its usually good for quite a while.
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Found the info I needed, 1.2 amps max, makes sense, seeing as it's a similar battery used in UPSs.
    (Note: this link contains some language, not for the kids)
    Fyrman's Reply
  6. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    My trailer came with a box similar to that except that it has a built in charging system... It charges off of the tow rig but it regulates it to what the battery needs to not damage it.
  7. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    thats not a trailer. Thats a monster! /forums/images/graemlins/rotfl.gif
