Breakin' brake lines loose.....
Discussion in 'The Garage' started by jwduke, Oct 29, 2003.
  1. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Breakin\' brake lines loose.....
    Ok, I know some of you guys here have broke brake lines loose a million times! Whats the easiest way to break them loose, without rounding the fittings off? I've been soaking them with PB Blaster....... Any ideas???
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: Breakin\' brake lines loose.....
    Use a flare nut wrench. You may break them anyway, but if you do, they're cheap and easy to make new ones. If you do round it off, cut it and use a 6 point socket to remove it.
  3. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    get those vise grips for nuts works for me every time , or reg vise grips if you dont mind messing em up a bit .
  4. Nitrodrip350
    Nitrodrip350 1/2 ton status
    Jul 22, 2001
    358
    Centennial, CO
    I hate brake lines, or power steering line, transmission lines .... well just about any hard line on my truck! /forums/images/graemlins/rotfl.gif Best thing is just soak them with penetrating oil the day before get a good flare wrench and tap them with a hammer to break them loose. Usually works pretty well.
    Good Luck, Shane
  5. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    A little heat works wonders.........
  6. Nitrodrip350
    Jul 22, 2001
    358
    Centennial, CO
    [/ QUOTE ] A BIT! /forums/images/graemlins/eek.gif All mine are nice and perfectly round because of the awsome fix all Vice-Grip!!! /forums/images/graemlins/rotfl.gif
    Shane-
  7. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Use a flare wrench and and strike it with your palm. You are almost guaranteed to round it off if you try to do it slowly. /forums/images/graemlins/thumb.gif
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    if you round them off then just use vise grips, youre gonna have no choice anyways, if ou need to reuse the fitting then you can, just drill out the line with 3/16" bit for 3/16" line or 1/4" bit for 1/4" bit, this will also clean up inside the fitting and then you can transfer to new line and flare the end and install on truck and vice grip tight no one will ever know what you did, ive had to do this several times in the past
  9. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    Or you could replace the fitting then re flare the line.
