Breakin' nuts on U-bolts loose
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jwduke, Apr 13, 2003.
  1. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Breakin\' nuts on U-bolts loose
    Ok guys, I know a lot of you have taken your ubolts off. I've got a IR impact wrench, with 600 ft.lb. of reverse torque. I've sprayed the sh*t out of these things with liquid wrench, and they will not break loose. Any ideas short of getting a fire wrench, to them??? /forums/images/graemlins/ears.gif
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    Re: Breakin\' nuts on U-bolts loose
    Cut em and get new ones. Re-using U-bolts isn't a good idea anyways.
    Rene
  3. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    TRU-DAT, i just put in my 14bff and used the old ones (old like december of 02) from when i put in the 14bsf, i wire brushed the thread, and hosed it with liquid wrench, and they came right off, granted they are only a few months old. when i did my lift in sept, i burned off the old ones and used the ones from the kit. New ones can be had for about 12 bucks each at the gm dealer, and a little more or less at other stores
  4. jwduke
    Aug 25, 2001
    721
    Thanks for the ideas guys! I wasn't planning on reusing them. These bolts probably haven't been off since '87. I've got new ones with my lift kit, and am doing the 1T, axle swap. I'll try the steel brush idea. Or else guess I'll have to see about renting a torch. /forums/images/graemlins/grin.gif
  5. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    cut off wheel...
    j
  6. jwduke
    Aug 25, 2001
    721
    cut off wheel...
    j
    Do they make a cutoff wheel for a 4" hand grinder? Great idea!!!!
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,075
    486
    Grand Rapids area
    I've used the gold anodized ones before and taken them apart and put them back together several times with no problems. The regular steel ones seem to freeze up in almost no time. It's so bad that you have to hurry up and do your re-torquing before you can't do it anymore.
    I have gotten ones a few months old free by heating them and cooling with liquid wrench a few cycles. Not the best approach, but if it's just for re-torque, there is no logic in cutting them off.
    So unless they are pretty new, stainless or anodized, just cut them off.
  8. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    yup /forums/images/graemlins/grin.gif
  9. MUD JUNKIE
    MUD JUNKIE 1/2 ton status
    Oct 24, 2001
    379
    Reddick,florida
    use a propane torch to heat them up then use the impact
  10. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    breaker bar + 6' cheater bar + 400lbs squat = 2400ft. lbs torque
  11. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    Walter "Zip-cut"...4"x 3/32", or 4 1/2" or 5" if you remove the guard. 1/8" thick is OK too, but the thinner the better for a cut-off wheel.
    Rene
  12. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    maybe it's to late, but if this is your daily driver, I would make sure that they sent you the correct u bolts b4 just cutting the old ones off, in case you need to run out and get a different set.
  13. scooby
    scooby Registered Member
    Aug 26, 2001
    62
    SURREY B.C. CANADA
    angel grinder? just grind em off. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  14. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Why not?!
  15. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    I agree w/ the breaker bar approach on old Ubolts. An impact will work fine on something that doesnt have any twist to it. Ubolts have some torsional twist to them and the impact will most likely just "bounce". Once they are broken loose an impact will zip them off. The longer the Ubolt, the worse it is.
    Same thing w/ tightening them back up. Fine to zip them down, but I always hit them w/ a breaker bar and no cheater and can usually get more out of it than even a big impact can.
  16. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    a cold chisel is cheaper, faster, and less damaging then most of the other suggestions.
    split the nut
  17. mplogic
    mplogic 1/2 ton status
    May 7, 2002
    263
    Phoenix, AZ
    That's about what it took to do mine. Lots of WD-40, A socket wrench, 6 foot pipe over the wrench, and a guy on each side of the pipe. Kinda like rowing a boat. /forums/images/graemlins/smile.gif They fought the whole way too, impact didn't do anything even after we got them turning. Took about a half hour, good workout though. /forums/images/graemlins/grin.gif
  18. jwduke
    Aug 25, 2001
    721
    Naw Subfan, thank goodness this isn't my daily driver. I really appreciate the help you can get at CK5!!! Only the best! Again Thanks for the help!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  19. chevystepside
    chevystepside 1/2 ton status
    Sep 23, 2002
    147
    leadville colo
    just get the blue wrench out and start cuttin. you should replace them anyway
