Breaking adhesive bond between cab hump and floor?
Discussion in 'The Garage' started by Russell, Feb 27, 2006.
  1. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    Hey guys!
    I need to pull an SM465 / 205 cab hump from a truck at the junkyard, but I can't get the thing off, lol
    I'm afraid of mucking it up prying on it the way I have to, but she won't budge!
    Any suggestions? Can't take any type of power tools, or anything that can make a spark into the yard...
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    On my old red blazer I took the hump off before we took it to the wrecking yard. It was sure stuck on there, I ended up using a prybar and hammering it in as far as I could. It bent a little but not too much. Just took a long time and a lot of patience:eek1:
  3. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Good strong 4" blade width paint scraper and a mallet. Tap-tap-tap all around the seal.
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Rubbing alcohol breaks down the adhesive a little bit, probably in your case just enough to get it loose enough to start prying. The tricky part is getting a little of the seal to break with a prybar or screwdriver so you can get the alcohol onto the adhesive. Once you get it a little loose, apply a little alcohol, pry a little bit, and repaet this all the way around the seal until you're done.
  5. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    little puddy knife/ small flat screw drive
