Breaking bolts in my D44
Discussion in 'The Garage' started by bugspray, Mar 16, 2004.
  1. bugspray
    bugspray 1/2 ton status
    Jan 13, 2004
    110
    Phx, Az
    Well it was my axle shaft that broke. I've got everything back together, except I need to know the ft #'s on the bolts that hold the carrier (The bearing caps). A friend that just got done redoing the axle seals on his truck said that those bolts call for 75-100 ft #'s. When the first bolt broke, we assumed the bolt was already cracked, so I went and got new 7/16 grade 8 bolts, all 4. When I went to redo it, I set the wrench at 60 first, did the bottom one, and thought it was the wrench doing it's job, so I went to the top. When it broke, the bearing cap fell off, and I realized both snapped. Never lend out your book! I'm going to have to give up on getting mine back, and get a new one, but in the meantime, anyone know the foot lbs it calls for? My other thought is the bolt is too long. I got the same size as the old one though. Any help is greatly appreciated.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A grade 8 bolt that big should NOT break a 75 ft lbs, but that is probably too much torque anyway.
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    85 ft-lbs is what my factory manual calls out for the D44 Bearings caps.
  4. bugspray
    Jan 13, 2004
    110
    Phx, Az
    Yeah I'm lost. I didn't figure they would break either. If it calls for 85#'s, and I'm breaking them at less (2 different torque wrenches) than that /forums/images/graemlins/confused.gif?
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    For what it's worth I don't think those bolts are just "regular grade 8". I would look into getting some GOOD bolts to replace them with!
  6. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Yup, they have a special shank and shoulder !
    But still something is not right
