Breaking leaf spring pins
Discussion in 'The Garage' started by cochino12, Aug 4, 2004.
  1. cochino12
    cochino12 1/2 ton status
    Dec 23, 2003
    563
    Parker, Co
    When I bought my k5 it had a broken drivers front pin, After the lift the same leaf spring pin is broken again after about 1k miles. I recently discoverd the blazer had been put on its side so I'm thinking maybe a bent frame? Any other reasons I would be breaking the leaf spring pin? thanks
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Every one I have seen was because the u-bolts wern't tight. U-bolts should be something around 140 ft*lb!
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    yeap my rancho lift said 150 big ones
  4. Grim-Reaper
    7,385
    Atlanta
    Measure the depth of the hole the pin goes in and measure the pin. If the pin is too long the spring will not seat onthe spring purch and the spring will have movement that it's not supose to and it could shear.
  5. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    Hmm, drivers side pin? Did you retorque the ubolts after a few hundred miles? They stretch and need it. My yota did this, loose ubolts.
  6. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    the driverside pin usually goes first because of steering
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Tighten your u bolts.
