breaking up at full throttle
Discussion in 'The Garage' started by 93h22cvc, Dec 12, 2005.
  1. 93h22cvc
    93h22cvc Registered Member
    May 3, 2005
    23
    milford ct
    i have a 88 k5 350 tbi. at anything more than half throttle it breaks up and has no power. i changed the fuel filter and it is still the same. the pump is also pretty new. any suggestions
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Well my first suspect was (is) the fuel pressure. You still might want to verify the pressure (regulator may be bad).
    Next would be the EGR, then the ignition module.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Have you Checked for trouble codes ?
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I've had similar issues in the past, and it ended up being bad plug wires. When's the last time you swapped in a new cap/rotor, plugs, and plug wires?
  5. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Yup....plugs & wires Im guessing because that happend to me.
  6. 93h22cvc
    May 3, 2005
    23
    milford ct
    there isnt any codes. my plugs and wires are about 4 months old.the other thing is after this condition happens if i shut it off and immediatly start it back up it will run normal for a few minutes. what a pain
  7. 93h22cvc
    May 3, 2005
    23
    milford ct
    the egr is not hooked up at the moment.
  8. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I still think its electrical.
  9. 93h22cvc
    May 3, 2005
    23
    milford ct
    can anyone tell me what the unused wire coming from the distibutor area with a female connector is for.
  10. jeeptuff
    jeeptuff 1/2 ton status
    Aug 22, 2005
    158
    Arlington, WA
    Tachometer
  11. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    4 month old wires can still go bad....Check the coil too, it may be going south....
  12. diesel4me
    Jul 24, 2003
    17,566
    942
    Massachussetts
    hope its not...
    CAM LOBES??.:eek1: ..every older GM V8 I had that a tune up didn't stop from breaking up at high speeds needed a camshaft..hope its not whats causing yours do do that...weak valve springs can let the valves float at high rpm and do much the same thing..you hear it "gargling" thru the intake at high speeds if it has bad cam lobes or bad springs..
    I'm not very up to snuff on later vehicles with EFI,so its possible on your truck it might just be a computer or sensor problem,or a pick up coil in the distributor,ignition problem,etc..but maybe pulling the valve covers and watching the rocker arms, and seeing if all are moving the same amount might not be a bad idea,and save you lots of non returnable parts bought for nothing....:crazy:
  13. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Distributor module.
