Breather hose questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MilpitasK5, May 6, 2002.
  1. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    Hey all:
    Anyone know what size the breather hoses are on the front and back diffs?
    I also noticed that my rear diff's breather hose goes straight up and cuts off. Should that thing be connected to anything?
    Probably a stupid question but I don't know =).
    Thanks,
  2. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    I think i used 3/8" fuel line for mine.
    And I connected mine to a fuel filter...to keep the dirt out of the diffs.
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Hey Chris... There is a clamp thingy that attaches to hose,then screws in the under side of the cargo bed.
  4. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Got it. Thanks Eric! Thanks Sherman!
    Peace,
  5. laketex
    6,220
    North Texas
    no prob nor cal!!! /forums/images/icons/wink.gif
  6. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    I think K&N makes a breather filter that goes on the hose.
  7. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    Mine has a little thingy on top of the hose which rattles around when i am moving to let air in and out
  8. GRINCH
    GRINCH 1/2 ton status
    Jan 30, 2001
    1,951
    Helena, MT
    Just replaced mine. It's 5/16" The front connects to a tube near the crossover and then gets routed to the engine compartment with a breather on it to stop water from getting in. The rear routes to over the gas tank and also has a breather on it.
    There were a few posts awhile back where peeps routed them to drier locations such as behind the filler door.
    Hope this helps
  9. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    mine's 3/8" and that little thingy on the end is a popett valve!!
