Breather tube
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1979Jimmy, Jul 11, 2002.
  1. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    Well my breather tubes to my differentials have all sorts of crap on and waround them and I want to lengthen them anyway. What size tubing shoudl I use?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I beleive I used 3/8 vacuum line. Mine are all extended up to the cowl on the passenger side. the tranny is the hardest to do, the breather on it has a little cap on it that you have to knock off, then you can hose clamp the vacuum tubing to it. A little silicone caulking to ensure the seal is a good idea too. </font color>
  3. jackedjimmy
    jackedjimmy 1/2 ton status
    May 18, 2002
    195
    Redmond WA
    you can also get 3/8 coiled airline. I put this on my diffs because the stock ones will rip out.
  4. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Yeah, the coiled stuff is kind of hard to route along the frame though /forums/images/icons/tongue.gif . I have had no problems with the vacuum tubing tearing out, just make sure there's enough slack in it. </font color>
  5. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    i went to the hardware store and got clear line for 7 cents a foot vs line from napa at 60 cents a foot...
  6. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    Where's the best way to route it all?
  7. reddog64
    Nov 9, 2000
    3,325
    i routed mine along the inner frame rail on the passenger side... along the gas and brake lines
  8. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Same here. Ran the rear axle line up the frame , brought the t case and tranny lines out there also, then tied all the lines together and ran them up through the engine compartment into the cowl. </font color>
  9. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Any concerns with venting equipment to a common line which use different lube potentially? I've had some instances of lube puking out vent lines. I'd hate to see ATF/GL mix. For instance I'm running an NV4500 transmission with GL-4 lube - it would definitely not like ATF for standard gear lube in the mix.
