breather woes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by joe84bb, Jun 12, 2000.
  1. joe84bb
    joe84bb Registered Member
    May 16, 2000
    45
    Florence, AL
    My Blaze is an ex-diesel truck so I don't have a stock breather to put back on it after swapping over to a gas motor. My problem is the aftermarket breather I bought goes out then down so far that some of my carb linkages hang on it...wide open...not fun , but an eye opener at 5:00 A.M. Where can I get an air filter and cover that goes either straight out or even out & up?
    I know just enough to know that I'll never know enough.
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Sounds like you need a spacer ontop of your carb, between the air cleaner and carb. I have one on mine, it's about 3" high and it kinda resembles a can but made for carbs......
    Hope this helps
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  3. CrazeeBush
    CrazeeBush 1/2 ton status
    Apr 17, 2000
    464
    Middle Tennessee
    what kinda of carb? I have the stock Q-Jet with an Edelbrock breather on top. It doesn't hang. Since you alreayd have teh breather, get a spacer like burt redcomended, I don't think they are expensive.
    -JoSH
    crazeebush@aol.com
    http://josh.coloradok5.com
  4. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    K&N have several different styles of air cleaner bases, check summitracing.com.
  5. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    Maybe you just need an inhaler.......j/k.
    L8r,
    .Riz.
