broke 2 spindle lock nuts..
Discussion in 'The Garage' started by Pow06er, Aug 19, 2005.
  1. Pow06er
    Pow06er 1/2 ton status
    Apr 9, 2005
    188
    ne, ohio
    ...while trying to use a wheel puller to remove the spindle.
    Anyway i have a junk 10bolt thats full time 4wd will it have the necessary spindle nuts i need to make it work with mine or do i need to get ones off of a manual lockout axle like mine
    the only thing i found similar was the warn convo kit had them in it but it was 50 bucks
    Im doing the 4" lift and we decided to do ujoints, rotors, pads, and were also doing driverside balljoints
  2. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Assuming both axles are 10 bolt or D44's the nuts should interchange. A D60 uses larger nuts.
  3. Pow06er
    Apr 9, 2005
    188
    ne, ohio
    so it has no effect whether its manual or locking?
  4. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    They will work
  5. sweetk30
    Nov 1, 2004
    25,554
    548
    horseheads , ny 14845
    do your self big favor . go get a dead blow hammer 4-5 lbs range. these work great for spindle removal and dont hurt them. just hit the spindle after the threads and go top / bottom then left / right. pops them loose quickly.
  6. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
    I used a 4" x 4" piece of wood and all my muscles to remove the spindles..the neighbours thought i was trying to demolish our house :wink1:
    would it be dangerous putting antiseize/grease between then spindle & knuckle so that they wont rust together?
  7. sweetk30
    Nov 1, 2004
    25,554
    548
    nope i do it all the time. just take file and get the small rust and crap out . then lube it up and bolt it on. good to go. this helped me years ago as my dads old plow truck would pop ujoints. i had it to the point of 30 min to change shaft out. and the lube on spindle helped big time.
  8. Pow06er
    Apr 9, 2005
    188
    ne, ohio
    we used an airchisel
