Broke a bolt off for my starter
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Zooman, Jul 7, 2003.
  1. Zooman
    Zooman Registered Member
    Jul 10, 2000
    35
    Ontario Canada
    I was taking my starter off again yesterday and the bolt seemed really tight. Anyway the bolt broke off in the block. Has anyone ever tried drilling out one of these. I know it is going to be a real pain but I need to get this done. My engine is a 350. Thanks
    Matt
  2. monte0172
    monte0172 1/2 ton status
    Sep 16, 2002
    182
    Memphis, TN
    I have done this before!! Just start out by using a punch to make a centering point for your drill bit then start small and go bigger from there and use lots of wd40 that way you wont burn up your drill bits. If you have any headers or exhaust in the way its easiest to take them off completely or move them as much as possible as to not obstruct angles. I have a set of left handed drill bits that sometimes make things easier for this. They sometimes will hook on the serew and remove it with out using a easy out. Good luck!!
  3. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I have also burned broken bolts out of a cast iron block before with a cutting torch.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    EZ out woiuld be highest recommended procedure to get it out,
    use one small enough aso that you dont have to drill a hole into broken bolt end that it cuts into thread in the block, or ytoull be in trouble
    be glad engine block did not break at the hgole, they usually break before the bolts do... you are lucky !
    tranny case mount bolt holes break allt he time, its all because of steel bolts threaded into other types of metal, try to soak with penetrating oil before remving such bolts
  5. Zooman
    Jul 10, 2000
    35
    Ontario Canada
    Are these bolts hardened steel?
    Isn't there a chance an ez out could break causing me alot of trouble? I am just trying to cover all my bases here.
    Thanks for the help guys.
    Matt
  6. dyeager535
    26,982
    191
    EZ out would be my last choice, as they are hardened, and if they break, make the problem even worse. Go through a bunch of threads on here with a search, and see the ratio of success vs. failure with ez outs. I bet the breakage ratio is over 50%.
    It *has* worked for some people, and if a bolt broke only because it was overtightened, (not stuck such as exhaust manifold or coolant passage corrosion) it would more than likely work fine.
