broke a rocker stud...will water come out when i remove it????
Discussion in 'The Garage' started by leadfoot067, Nov 8, 2003.
  1. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    my heads have screw in studs....broke one today....it let go at like 5900 RPMS... ....anyways do rocker studs protrude into the water jacket????.... trying to avoid water in my oil...
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Re: broke a rocker stud
    yes there is water waiting to come out once you remove the studs...atleast on some heads. My buddy who works at the machine shop kept getting water in his oil.. turned out the pressed in studs leaked.
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    usually not. are you running a performance cam? are you running longer slot rockers? screw in studs are stronger than stock. usually a reason when they break.
  4. leadfoot067
    May 14, 2001
    1,563
    the heads are world products..SR torkers.....the cam is only a 260 comp cams..understand these heads have been on my oval track race motor for a few seasons.....running a very big cam,,,,with roller rockers and yes the geometry on the rocker vs pushrod length is correct....the rockers ride on the valve tips right where they should.......i just couldnt remember if the stud holes entered the water jacket.... i believe it broke just from stress of the previous motor seeing 7200 rpms regularly....... i have another set of screw in studs...mabye ill change all of them....
  5. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    ok, some people have overlooked the rockers. But your on the ball, i see! but if 1 is stressed, I'de change them all.
  6. leadfoot067
    May 14, 2001
    1,563
    ya when i first got these heads a few years ago....the geometry was terrible with stock length pushrods.....ended up .125 longer pushrods to make them work.......but yet they are supposed to be a bolt on stock replacment head..... /forums/images/graemlins/confused.gif..o-well the HP is worth the cost of longer pushrods.... /forums/images/graemlins/thumb.gif
