Broke a tooth off a spider gear
Discussion in 'The Garage' started by zcarczar, May 17, 2005.
  1. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Broke a tooth off a spider gear in my front ARB. Should I run it?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    ARB? I am confused. Though i will admit i don't know much about ARB's internally, i did not even know they had spider gears
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    ARB's have spider gears (about the only thing that makes them weaker than a detroit), they use the compressed air to lock one of the side gears, thereby locking the differential. I would replace it, assuming you already found the tooth in your diff (before it blew up the R&P :shocked: ), it will cause problems down the road. Better to replace a $25 (guessing) spider gear than a whole new ARB, diff, install, etc.
  4. readymix
    May 30, 2004
    6,706
    26
    Thatks for the info on the guts of the ARB. I will have to look into that and educate myself a little bit
  5. zcarczar
    Feb 10, 2002
    2,495
    Yeah, during a little more investigation I found another broke tooth on the same gear. So I will be replacing it now.
