broke again
Discussion in 'The Garage' started by grindkings, Jun 8, 2005.
  1. grindkings
    grindkings 1/2 ton status
    Dec 24, 2004
    127
    Marshall, Missouri
    I installed my lift about a year ago. Couple of months after that my 10* wedges broke off from under the springs. So i called RC and the sent me some new ones. GUSSE WHAT THEY BROKE AGAIN. I hat having to take the springs apart. Who makes some hevy duty ones that arnt' going to snap on me again?
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Get some steel ones. There are a few guys on here that can make them and a lot on PBB that will do it too. I am having some custom length ones made for myself.
  3. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    JKW Offroad
  4. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    cut and spin the axle and reweld the perches.
  5. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Gotta get steel ones. that or just have someone make a set of zero rates for you with a 10* shim.
    The angle shims will crack if made from the cheap aluminum. If the two mating surfaces are completely flat, they tend not to crack. However, every axle i've seen is less than flat...
