broke an intake bolt...
Discussion in 'The Garage' started by TruckNutzDude, Dec 25, 2004.
  1. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I just broke my thermostat bolts off in the intake. Normally I'm not scared to drill and ez-out a bolt but the intake is aluminum. Is there any special procedure to getting a bolt out of aluminum? Can I just cut it flat, center punch it and drill it out like normal??
  2. cyclone
    cyclone 1/2 ton status
    Oct 11, 2004
    243
    Sonoma, CA
    broken bolts
    The best way is to grind flat then center punch, then drill w/left handed drill bit. It usually backs out the piece before you're even all the way through. Vermot American and Irwin are the two brands I've seen.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Worst case scenario you heli-coil it. That's what I had to do to my intake. PO of the intake stripped the hole and tapped it to 7/16-14. I pulled the half ass tapped thread out and had to drill it and heli-coil it back to the correct 3/8-16 size.
    No problem, piece of cake. :)
  4. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Another option, if you can get in there, is to weld a nut on top -- thread it down as much as you can, then fill the center.
    Took me *seven* tries last week to do this (I'm still learning to weld, can you tell? :blush: ) ... but the seventh one did the trick, backed right out.
    -- A
  5. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,922
    333
    Fort McMurray, Alberta
    What the guy above me said -- I went through this with my all aluminum TPI intake. The bolts react with the aluminum causing them to fuse together much like a rust bond. -- Simply weld a nut onto the broken bolt, then give it a few sharp blows with a hammer to break the corrosion bond (heating it up by welding will help as well), then back the nut out :) I broke the nut off a couple times as well, but eventually got it out. Make sure you clean the threads out with a tap after you've finished and use some anti-seize on the bolts you install later on :)
  6. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    it works!!!!
    the welded nut trick realy work put you need to take your time. i have had to apply some heat to the intake before to help with this. best of luck.
  7. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    I did the same thing but then i broke off the screw extractor in there cuz i was being retarded and used the smallest one i could. I just tapped the extractor down, redrilled and retapped and put a stud in its place and its all good now.
    Later
