Broke ball joint wheeling
Discussion in 'The Garage' started by toy4x4runner, Mar 4, 2006.
  1. toy4x4runner
    toy4x4runner 1/2 ton status
    Nov 3, 2004
    122
    Tampa, FL
    last night I was doing some wheeling and my RF tire came out from under my truck. Lower ball joint broke! I've been running Spicer Ball joints for the past 2yrs in this axle. I had a feeling the ball joints were getting some slop in them, but didn't think they were that bad. Boy was I wrong. It turned into a Big ordeal and I had to have the truck dragged to the trail head and a tow truck drag it up on the flat bed. Now, my Question is... is breaking ball joints common on the D44's? What brand ball joints are the strongest? I'm thinking about just going to Napa for some premiums. B/c of this lower ball joint, it broke my inner axle shafts and TRE's.
  2. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    This was one of the few ball joint breakages that I have heard about in quite a while. I run Moog ball joints, with 39" boggers. No breakage issues yet.
  3. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I would agree that it is not a super common issue, however if you know they are getting worn and sloppy, then its probably time to replace. I started getting death wobble and thats when I replaced mine.
  4. George_Pimpdaddy
    George_Pimpdaddy 1/2 ton status
    Oct 17, 2002
    1,306
    Edmonton Alberta Canada
    that musta sucked ass having it break on the trail
  5. toy4x4runner
    Nov 3, 2004
    122
    Tampa, FL
    Yeah, really sucked ass. But I knew the Ball joints had play in them. I just didn't think they'd actually friggin break. I figured they'd get more slop. People seem to be giving Moog a thumbs up on multiple boards. would you guys run Spicer Ball joints or Moog if you had the option?
  6. azblazer
    azblazer 1/2 ton status Premium Member
    Jul 20, 2003
    695
    15
    Grand Junction, Co.
    I run nothing but MOOG....
    DW
  7. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I've always liked Moog best for steering parts
  8. toy4x4runner
    Nov 3, 2004
    122
    Tampa, FL
    I talked to a local older parts guy and he also recomended MOOG for ball joints and TRE's. Looks like i'll get some Moog BJ's and TRE's and then some axle ujoints from work... some Brute Forces. Thanks guys. I got it taken apart this morning. here are some pics:
    http://share.shutterfly.com/action/welcome?sid=2AaMWjdi5YsXqQ&notag=1
    that's a Dutchman inner short axle shaft and a Stock later style stock stub shaft and I was running spicer axle joints.
  9. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Make sure that the axleshaft u-joint was not what broke first. The only balljoint failures I have seen were caused by the u-joint failing and/or the u-joint caps coming out of the yokes. When this happens it can spin around and catch on the inner part of the knuckles and easily pops the balljoints off.
  10. toy4x4runner
    Nov 3, 2004
    122
    Tampa, FL
    ok... well my lower ball joint is still in the inner C. and it has the "ball" on the bottom still. It's like the lower BJ popped out of the socket. b/c both joints were still in the inner C. what does that sound like?
  11. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    Of course you were driving it so you should know exactly what happened. But what 6.2 mentioned is more common than an actual BJ failure. The shaft's ears or the u-joint fail and then cut the BJ. The other common failure is from an improperly preloaded upper causing too much slop.
    And to answer your "?" I like Moog for steering parts, and Spicer for u-joints.
  12. toy4x4runner
    Nov 3, 2004
    122
    Tampa, FL
    well when I built the axle about 1.5yrs ago I did NOT adjust the upper BJ preload like I should of. then about 3 months ago I did a "axle fresh up" and had the outer knuckles off. and the BJ's had VERTICAL Play. I was/am broke as crap so I put it back together... now I see it cost me even more money. and now I know how to "preload" the upper BJ and install them. Parts Mike has a HOW TO on it. torque sequence and stuff. but heres a better pic of the lower ball joint:
    http://share.shutterfly.com/action/welcome?sid=2AaMWjdi5YsXuA&notag=1
    Only thing I felt when driving was the front right drop down. nothing else.
  13. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    That will do it ever time. Good luck on the repair, PM has some great stuff.
